May 22, 201214 yr comment_3324 Hi guys. My rear side windows are deteriorating quickly around the seals on the outside. I am setting it up as a camping bus do was thinking of removing the whole sliding window setup and replacing it with a solid piece of either glass or perspect? Has anyone seem this done? Secondly can the outer rubber seal and trim strip be purchased anywhere?? My local rubber place say they've never seem it before.. Any help appreciated. Cheers Report
May 24, 201214 yr comment_3571 I don't think the rubber on the original windows can be replaced because the whole thing is molded around a steel frame and it's the frame that rots out and wrecks the window. There are people around making one piece glass window replacements with a rubber seal and even a version with a custom aluminium frame. A google search would turn up results on these. People have also made the windows into doors similar to ute boxes. Shouldn't be too hard to do if you can find the right rubber seal profile to seal the door against. I'm not convinced that as a door they are of any great use, but I have seen pictures on ** ahem ** another patrol site where some guy had shelves, possibly even a mini-bar mounted, behind the windows come doors. On the subject of perspex, I'd avoid it if possible as it is easily scratched and damaged compared to good old fashioned safety glass. Report
May 24, 201214 yr Author comment_3573 Thanks I was thinking Perspex because you can get it thicker (10-14mm) and pre tinted.. Once my draw system is in there will be no use for a window at all.. Report
May 24, 201214 yr Author comment_3574 Well your right.. Will be ringing tomorrow http://www.nissanpatrol.com.au/forums/showthread.php?5420-Nissan-patrol-fixed-side-glass-with-rubber-new-lwb Report
May 28, 201214 yr comment_3934 There's a fella on eBay that sells after market, full length and sliders for a very reasonable price..... If I track it down I'll post it up Taps a lot!!!!!! Report
May 28, 201214 yr comment_3939 Can't work out how to copy a link from mobile eBay, nevermimd,....... The sellers name is ozautomouldsrubbers. Sliders are $405 a pair and solids are less...... Do a search, have a gander but they look pretty good to me Taps a lot!!!!!! Report
May 29, 201214 yr Author comment_3971 Yea sorry, rang them last week.. $160 a side and $50 postage to me.. Very cheap.. Just gotta save for it.. Report
May 29, 201214 yr comment_4026 All good, had to remind myself anyway..... Want to get the sliders soon Taps a lot!!!!!! Report
