October 15, 20215 yr comment_11257 First of all Yo Yo, I'm new My flagship : Patrol Y61 2003 ZD30 270000km And now, problem... not first not last... I’ve changed oil 3000 km ago with 1mm more than max and up to this day it was same - zero oil lost. Last week, First day of trip we did hard and long downhill, I used reductor and mostly on 1st gear without brake. when we finished, under the mountain my Y61 on idle shown bright grey smoke from exhaust - something super new - there was no smoke so far, almost zero, and never on idle. But on higher rpms it was ok, so I continued travel, with few more incidents on idle but not very long. Next day morning i checked oil and from bit more than max was minimum. I add 1 litre and it is again bit more than max. Second all day it was ok, without smoke, and after all day driving I checked oil at home and is ok, But on third day on cold it shows bit too much, like 10mm above max. So, what obvious reason of such behavior with smoke can be? I can't understand how oil could be consumed. And this smoke? It is problem to have such over fill? Another detail I just discovered, don’t this it is connected with basic issue, but actuator rod is drifting a bit on idle, it is lifted on idle but is moving +-5mm So, thanks in advance for comment and regards to ALL. art Report
