Patrol wont start
ok so temporary clear line fitted to see if there is air in the system and primed but still wont start. obd scan initially came up again with P0089 - fuel rail pressure - code cleared but no start. Glow plugs replaced, fuel pressure relief valve replaced, fuel filter replaced - system bled of air. starts with starter spray but will travel approx 500 metres before shutting down. have attached a video with car running with some help from spray showing fuel line (no bubbles), OBD2 scanner showing fuel rail pressure and also truck trying to start on it s own. hoping someone might have a clue, cheers simon (will let it settle and check for air in lines in an hour or so) fuel on top of filter is just overflow from lines while hooking them up - now cleaned up
