May 11, 201213 yr comment_1510 Well here are some pics of wiring diagrams if anyone wants to convert there winch to have a kill switch and in-cab control. They are just to give you an idea as I had these pics saved from when I did a similar setup. Uses could be to remotely locate the solenoid pack in an out of the way place, to minimise its exposure to water and mud. Or simply for winching convenience. I liked the idea of having a switch which stops the solenoid pack plug from working unless the switch was on. Report
