June 6, 201213 yr comment_4515 Hey guys, Just wondering where I can find the balance tube or whatever its called to allow a snorkel to be fitted to an LPG vehicle with the head facing forward. Cheers Report
June 6, 201213 yr comment_4529 Ive never heard anyone mention a "balance tube" for a snorkel before. I've seen questions asked about differences for lpg snorkels but answers have always been "no change required". Why would you? I can't imagine what modifications would need to be made to any snorkel, for any fuel, regardless of inlet direction. Anyone else? Report
June 7, 201213 yr comment_4542 Hey mate heres the balance pipe I installed. Pics say a thousand words.barb in airtake is cut at a angle to catch some flow. Ive had no issues even at top speed (down hill)lol. Sent from Brett's Galaxy using Tapatalk Report
June 7, 201213 yr comment_4558 Pics say a thousand words. Sorry Brett, I still don't get it. The pipe balances what? What problem/s did snorkel fitment cause that balancing is needed? Would you elaborate please. Report
June 8, 201213 yr comment_4578 I thought a balance pipe for LPG is really only needed for a turbo setup. I think the balance pipe you are referring to is also called a boost reference for the converter. Usually in a naturally aspirated lpg system the cover of the converter just has a small mesh screen on it. If you run a turbo the balance line should be just after the turbo to the converter. Report
June 8, 201213 yr Author comment_4583 I just heard from a few blokes that without this pipe or tube too much air is forced in causing problems with the LPG. Report
June 8, 201213 yr comment_4590 It used to play up big time on my TB42 GQ used to stall if you put into neutral while driving along Report
