Art Posted October 17, 2021 Report Posted October 17, 2021 Sorry, I put that topic in to General discussion but rather should be here, My flagship : Patrol Y61 2003 ZD30 270000km And now, problem... not first not last... I’ve changed oil 3000 km ago with 1mm more than max and up to this day it was same - zero oil lost. Last week, First day of trip we did hard and long downhill, I used reductor and mostly on 1st gear without brake. when we finished, under the mountain my Y61 on idle shown bright grey smoke from exhaust - something super new - there was no smoke so far, almost zero, and never on idle. But on higher rpms it was ok, so I continued travel, with few more incidents on idle but not very long. Next day morning i checked oil and from bit more than max was minimum. I add 1 litre and it is again bit more than max. Second all day it was ok, without smoke, and after all day driving I checked oil at home and is ok, But on third day on cold it shows bit too much, like 10mm above max. So, what obvious reason of such behavior with smoke can be? I can't understand how oil could be consumed. And this smoke? It is problem to have such over fill? Another detail I just discovered, don’t this it is connected with basic issue, but actuator rod is drifting a bit on idle, it is lifted on idle but is moving +-5mm So, thanks in advance for comment and regards to ALL. art
Rumcajs Posted October 18, 2021 Report Posted October 18, 2021 Actuator should not be moving up/down at idle. It means there is a vacuum leak somewhere. If yours has vac canister those usuallu leak.... It is safe to just bypass it to check leave out. Cheers
Art Posted October 18, 2021 Author Report Posted October 18, 2021 Hi Rumcajs, and I've noticed that actuator moved just after start, when car was hot it did not, maybe it is coincidance, or nor depended on temp, I will check this vac canister. but isn't connected with oil lost and smoke on iddle, right? thanks again for comments ! art
Art Posted October 21, 2021 Author Report Posted October 21, 2021 Well, something weird. I just took out this 1 litre which I add, which caused such high overfill, and the level is like it was, before all this strange story. I checked oil in the morning before engine start and level showed minimum, but it wasn't in fact, that is even more strange.... so there was a bit of smoke but it looks it wasn't due to burning of so much oil as I thought. now I need to know why oil level check was not real regards art
Blackflag Posted March 25 Report Posted March 25 Sorry to revive an old thread but I am having exactly the same issue and I cannot seem to find an answer to this. Any updates to this @Art?
