Dronus4x4 Rear Recovery Point Build up
Ok, this is just a scratch area to keep ideas on building my rear recovery point.
Once its built and confirmed to not kill anyone ill post it in the Recovery Points Thread.
The Problem:
The Telstra bar on the back of my GU doesn't have a hayman Reece hitch, so i cannot use the normal recovery insert. Make something stronger.
The investigation:
I took the tow pintle off and was happy to see that the bolt layout is the standard for 4 bolt tow hitches. The tow hook that was fitted on the back step fit fine, however i need something much stronger.
So i ended up with something like this until i work out the new recovery point.
I have seen a couple online, and maybe ill find one at an auction, but im thinking of getting something like this made (yes i suck at google sketchup)
I have seen these online - but they are very expensive!
Maybe get something like this and weld it on? My mate is a certified welder
http://cgi.ebay.com....atchlink:top:en
There is also this, but i dont know how good it is
http://www.ebay.com....=item27b68f7ff7
How about this?
Still working on this, stay tuned................
Edited by dronus4x4
