April 12, 201214 yr comment_207 My Southern Cross camper trailer (Bush Mate) .It was a ex demo and got it last july. It came with the following 9ft Tent Kids room Safari roof Full annex with walls Slide out stainless steel kitchen 80L water tank Large tool box 2 x Jerry can holders 9kg Gas bottle and plumbed to rear of trailer with quick release coupling Treg coupling LED brake and clearance lights 12V system with 110 amp battery Electric brakes Hand brake Report
April 17, 201214 yr comment_218 Looks like you use an electric pump for your water - I have a hand pump, just like the one on the left of your sink, but the wife and I hate pumping it.. got a reccommendation for an electric pump I can put under the camper to make things a little easier? Report
April 17, 201214 yr Author comment_219 I used a 4.3LPM pump but a 3.8LPM would do the job. I got mine from Opposite Lock this one http://www.enmachind.com.au/poly-rv-accessories/tank-fittings-accessories You don't need a big pump to use a lot of water in the bush and you are not running a fire hose. I all so have son/off switch on mine but it turns off automaticly when the tap is turned off. Report
April 17, 201214 yr comment_220 Cheers for that.. I dont suppose you have ever plumbed it in to the manual hand pump? Im wondering if water will just flow out of the hand pump spout if the electic pump is on.. If it does then great otherwise im going to need to find a new tap to. Report
April 17, 201214 yr Author comment_221 Cheers for that.. I dont suppose you have ever plumbed it in to the manual hand pump? Im wondering if water will just flow out of the hand pump spout if the electic pump is on.. If it does then great otherwise im going to need to find a new tap to. Yes you can and I did but you need to switch it on and off. Also put a bypass in pas the pump with a valve so if the pump stops you can still pull water threw the hand pump. Thats what the two valves are for in the photo. As you can see my pump is in the side hatch of the trailer. Here is a pic of the under side. Report
April 30, 201213 yr comment_320 Great looking trailer. I hope to get one when we finish the house. Report
