May 23, 201213 yr comment_3490 Any one looking for Leds for your rear doors check out this bloke. http://www.ebay.com.au/itm/270961586205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 This is how mine turned out. Very happy with the lights Makes it easy to see in the fridge. Report
May 23, 201213 yr comment_3503 I bought something similar to do the same, but after finding out that there's not on single power wire in the rear door, I couldn't be fagged pulling one through the rubber harness cover. Cheers Ray Report
May 23, 201213 yr comment_3504 Being into RC stuff this is what the father in-law and I have and will be using.. http://www.hobbyking.com/hobbyking/store/__14290__High_Density_Waterproof_LED_Flexible_Strip_White_1mtr_.html Edited May 23, 201213 yr by BigGQWesty Report
May 23, 201213 yr Author comment_3516 I bought something similar to do the same, but after finding out that there's not on single power wire in the rear door, I couldn't be fagged pulling one through the rubber harness cover. Cheers Ray The kit suppies al the wiring to pick up power from the rear interior light, He supplies a step by step instruction sheet and every thing you need to do the job. Cheers Dave Report
May 23, 201213 yr comment_3517 I have power available in the rear panels, but now that the table is solidly mounted, I can't be bothered to drag wires through. I just hang an LED light on the door. Cheers Ray Report
May 27, 201213 yr comment_3792 I have seen these but why not run a long strand along the sides and top of. The rear cargo area ,then you don't have to pull wires through to put power onto it I'll take some pics when I finally get mine sorted out with draws etc have bigger problems at this time Report
