Aslam Posted April 15, 2017 Report Share Posted April 15, 2017 (edited) I own a MY 16 Y61 2 door 4.8. I installed the Old Man EMU nitrogas charger shocks and asked for a 2 inch lift as well. They advised against the lift due to vibration issues above 80kmh, despite trying gearbox spaces, etc. is there any experience on the group to advise? Edited April 15, 2017 by Aslam Link to comment Share on other sites More sharing options...
Rumcajs Posted April 16, 2017 Report Share Posted April 16, 2017 G'day, I'm afraid there isn't much experience with the short wheel base Y61 in Australia for example, so it is an unknown behaviour. OME doesn't do the suspension lifts anyway it is basically just under an inch raise if that and that is it. And they always advise against any lifts. Suspension lift itself is not a cause of vibrations, usually it is the change in drive line angles and steering geometry which is responsible so if you can recalculate the angles and return them to be as close as to factory setting there should be no issues. IMHO 2" lift should be fine without any other changes. Regards Link to comment Share on other sites More sharing options...
