May 30, 20197 yr comment_9399 can anyone one give me an idea of how to bypass rear brake sensor, which pipes do i rejoin also which one to blank off, this vehicle also has abs fitted so i am hoping i can do away with the rear sensor any advice would be realy helpful or maybe someone has a video tutorial on this. Report
June 4, 20197 yr comment_9416 G'day, I'm at a loss to understand what is your objective? Short answer is that you can't just 'bypass' ABS rear sensors. I'm assuming the wheel speed sensors, am I right? If you want to just disable ABS functionality then just remove relevant fuses. It will be standard brakes with anti lock function removed. Regards Report
