October 31, 20205 yr comment_10736 Hi all, I have a 2012 ZD30 that I need to put a catch can, problem is where. With a duel battery and other after market electrics, the usual spots aren't available. Is distance an issue if I mount it further away from the engine? Report
November 1, 20205 yr comment_10738 Well how far away? As long as it is in the engine bay you should be OK. Report
November 11, 20205 yr Author comment_10764 It would have to go on the outside of the Rad' support panel Report
