December 13, 20205 yr comment_10919 Hi everyone I’m just looking at buying a 2009 zd30 with 200 on the clock and was checking for blow by after running the car pretty hard at the test drive, I opened the And a bit of oil and smoke were spurting out. Just wanted to see if this was a patrol thing or I have something to worry about cheers Report
December 14, 20205 yr comment_10925 I'm not sure I follow but yes ZD30 engines have a bit heavy breathing. I'm assuming you took a hose from the rocker cover breather off.... If there is no catch can on that thing after 200K I'd be checking what the intake manifold looks like, pretty much guaranteed that port holes are half the size by now from carbon and oil deposits. Sadly it is no quick fix either..... Not sure I'd want that thing unless it is extremely cheap. Regards Edited December 14, 20205 yr by Rumcajs Report
December 21, 20205 yr Author comment_10945 Thank you and sorry when I took the oil cap off there was a bit of oil and smoke was seeing if that was a normal thing in patrols im only used to Toyotas On 12/14/2020 at 7:21 PM, Rumcajs said: I'm not sure I follow but yes ZD30 engines have a bit heavy breathing. I'm assuming you took a hose from the rocker cover breather off.... If there is no catch can on that thing after 200K I'd be checking what the intake manifold looks like, pretty much guaranteed that port holes are half the size by now from carbon and oil deposits. Sadly it is no quick fix either..... Not sure I'd want that thing unless it is extremely cheap. Regard Report
