November 5, 20214 yr comment_11269 Iv just replaced my drive side door. When I try to use the auto up function on window. It goes up then just comes back down 1/3 of the way. Any ideas of what could be causing this issue ? Report
November 8, 20214 yr comment_11273 G'day, You are not telling which version of yours but chances are you will need to reset the limit switch. I'm trying to upload the instructions but it seems to fail so text only:(false alarm it seems it doesn't like Firefox web browser) Front Door Limit Switch Reset (Driver side only) RESET CONDITIONS After each of the following operations are performed, reset the limit switch (with built-in motor). I Regulator removal and installation I Removal of motor from regulator I Operation of regulator as a single unit I Door glass removal and installation I Glass run removal and installation RESET PROCEDURES After installing parts, proceed as follows: 1. Close the door window completely. 2. Press the reset switch and open the door window completely. 3. Release the reset switch. After making sure the reset switch has returned to the original position, close the door window completely. 4. The limit switch is now reset. CAUTION: Be sure to manually open or close the door window. (Do not use the automatic open-close procedures.) Report
November 8, 20214 yr Author comment_11274 Thanks heaps!!! it’s a 2003 gu 3lt turbo diesel will give that a go tomorrow. Really appreciate the help 👍👍 Report
