December 16, 2025Dec 16 comment_12617 Hi all, Did anyone fitted a Auscruise Drive by wire to the Patol Zd30 ? I do have a used one, but no idea how to connect it. Any help will be highly appreciated. Report
December 18, 2025Dec 18 comment_12618 Hi, I don't have this particular C/C setup, mine is Italian E-bay special with genuine Nissan SW CC control swiches and the hardest thing to figure out was which wire on the clock spring I was suppose to connect to as mine was 05 model with different color codes. Anyway here is an example of installation instructions concerned... Also be aware that manual is from 2005 therefore it is not applicable to CrD version of ZD30 or after 2007. Since you have not informed which version is yours I'd thread carefully with that cruise control if yours is a later series, possible applicable only up to series 4 (2006) Nevermind, I've already found out that you have that manual already and yours is Series 4. So my entire post was just waste of my time...I'm leaving up here for if someone else needs it. Cheers AutronAuscruiseZD30InstallationInstructions.pdf Edited December 18, 2025Dec 18 by Rumcajs Report
