May 1, 201213 yr comment_347 My blinkers stopped working the other week (don't worry the MK isn't registered yet) and I have been trying to figure it out, testing the different wires and such. Tonight I thought I'd check the hazard switch and what do you know it was buggered. Mq mad (p4x4) gave me one so plugged it in and presto, blinkers. Now to get the horn working. Report
May 2, 201213 yr comment_416 Good work mate Pull the steering wheel off or at least the surrounds and see if the brass horn contact is making contact with The slip ring on the back of the wheel, they have a tendency to wear down and not touch Report
May 5, 201213 yr Author comment_749 the horn had a couple of problems 1) there wasn't any brass rod, so I cut a nail at the height and 2) the wire from the relay to the horn was stuffed, so I put a new one in. hey presto works a charm. One more thing to tick off the list. hoping to get it on the road by the end of this month. if the accountant let's me. Sent from my iPad using Tapatalk HD Report
