May 5, 201313 yr comment_7242 Recently I finally finished glow plugs timer Kemo M113A from Jaycar fitment however decided to use my twist on the design from a member @P4x4 forum. I fully recommend doing this mod especially on ZD30 as the amount of time Mr Nissan keeps the glow plugs on borders/is ridiculous/insane. The subsequent damage to glow plugs, engine head etc has been well documented.Its relatively easy to do hardest part is to find courage to intercept ECU's the control wire/s. I have added my own twist by using built in dash glow indicator to let me now. Its not strictly necessary as Kemo timer has its own built in LEDs. I might connect additional momentary push button switch (Timer has a provision/terminals to connect)to stop glow plugs activation as I have noticed that "glow" happens unnecessary e.g. when coolant temp is bellow 70° but above 60° and ambient temperature is above/around 20°Cheers Note: depending where it is going to be fitted, (mine is inside) sourcing positive feed from alternative location is recommended e.g. ignition fed perhaps T-off from 12 V aux supply. Edited May 5, 201313 yr by Rumcajs Report
August 17, 201412 yr Author comment_7998 Update: There appears to be latest revision/batch (24024OM) of the timers from Kemo no longer work as automated per diagram above. Timer needs to be powered before actuating circuit is otherwise the timing trigger doesn't work anymore. Possible options are to fit just momentary manual switch or use something else. Cheers Edited August 17, 201412 yr by Rumcajs Report
