May 16, 201313 yr comment_7270 Okay.. So my Maverick is developing an issue.. Grinding noise / rattle in the front left wheel.. Appears after 40kph.. Disappears under 40kph. Wheel bearings are in good shape.. Had a wheel wobble recently but replacement draglink fixed that.. Just had the brakes done.. It does it if you roll downhill with engine off.. Both hubs heat up evenly... I'm a bit stumped. It's a significant grinding noise.. But only sometimes... Where do I start?! Report
May 17, 201313 yr comment_7275 This could be the results of having brakes done, something left loose, did you have rotors changed as well? Cheers Report
