August 8, 201313 yr comment_7431 Hi, I need help on how to replace a headlight on Patrol GU Y61 (made in 2005). By removing the grille Igot acces to 2 bolts holding the amp, but there is still something holding it under the mudguard. Any idea how to completely remove the lamp (to relace it)? The lamp image is attached Many thanks, Monel Report
August 9, 201313 yr Author comment_7434 Hi, Probably not the right phrase! The question I wanted answered was How to replace the head lamp on Patrol GU Y61, 2005 model Thanks, Monel Report
August 11, 201313 yr comment_7436 There should be another screw holding the assembly on the indicator side, it is accessible from underneath (or is on mine as I don't have factory bumper anymore it is clearly visible when looking from under the bullbar in my case). Cheers Report
September 22, 201313 yr Author comment_7506 Thank you. Found the screw, but it is inaccessible to any spanner/socket without removing the bumper...So it will have to wait till I summon the energy to do it. Monel Report
