March 24, 201412 yr comment_7805 Hi just became a member I have a 2001gu patrol with 271,000km. Will it blow up soon? I'm not sure what it has had done to it. It runs at around 10-15psi but is a bit laggy? Thanks Report
March 24, 201412 yr comment_7806 Hi there, Congrats on passing the magic 140,000 km mark after that they suppose to blow up anytime... if you listen to TD42 owners that is. Standards ZD30 is very laggy anyway and running boost at 10-15 psi is alright. Fitting needle valve and Dawes will take care of the lag. Cheers Report
