October 26, 201411 yr comment_8118 I have a 2002 zd30 just wondering how much blow by from the rocker cover vent is to much? Or am i suppose to be getting any at all? Report
October 27, 201411 yr comment_8120 I would have thought bugger all.. If you getting oil flowing out then that's not good. A bit of vapour is fine. Report
October 27, 201411 yr comment_8121 There is no definitive answer as a lot depends on the condfition and mileage of the motor. ZD30 are known to breath a little, major culprit is the amount of oil in the sump. Almost everyone overfills it. Nissan stated volume of 8.2 L is too much. It takes a while to drain all the old oil out so retail servicing job will always make the level way past the max. Do the measurement first thing before you start the engine in the morning, you gonna get a nasty shock from how far above the max the level will be. All that excess oil causes it to be pumped out of the breather. Regards Edited October 27, 201411 yr by Rumcajs Report
October 27, 201411 yr Author comment_8123 Hi guys thanx for the replies Its not over full with oil. I'm getting more vapour out of the hose than actual oil. I know that's why i have to put a catch can on because they do spit out little oil anyway But more my concern is the vapour. I just fitted a new turbo so i don't want it damage it Report
October 27, 201411 yr Author comment_8124 Patrol reads 200,000kms i just bought it hasn't got any mods on it at all Report
October 28, 201411 yr comment_8128 Fitting catch can doesn't do anything to affect the blow-by however it will keep the oil mist out of the intake which is essential to engine health. Regards Report
January 23, 201511 yr comment_8230 Hi all, I have a similar question. I am currently looking to buy a Patrol and have seen a few. Most are pushing smoke out of the oil filler cap (a trick I learnt to check the rings) and one was pushing air out like the vents in the cab with the fan on high. I realise they need to push out some air but I too am curious as to what amount is considered normal and what might be causing excess air to be exhausted this way. If there are any other things I can look for when purchasing that would be highly appreciated, will be checking out a 2003 GUiii 3L with 260k, 5 speed manual tonight. Add says it has full NADS kit with diff breather and 3" dump & exhaust - hoping it is in good nic as I would love to own it. Report
