March 17, 201511 yr comment_8277 Hi, Just wondering whether anyone has had any luck purchasing aftermarket inter cooler hoses for the ZD30DI? I would like to replace mine but would love to purchase new ones first so i can swap straight over as opposed to removing hoses & taking somewhere to match up. any info appreciated. Cheers Report
March 19, 201511 yr comment_8278 Good luck with that one mate.What you can do is, measure all the ODs required and than chase the silicon hoses as required. Don't forget to update the hose clamps to good quality T-clamps or spring loaded constant tension clamps.Regards Report
March 22, 201511 yr Author comment_8280 Cheers for the reply. That was the plan but thought id see whether anyone had the info. I will put some info up once i have found all the bits. Report
