May 21, 201610 yr comment_8823 Looking a buying a 2012 3lt Patrol in an automatic but have never owned an automatic 4wd before.. Could you please share your pros and cons it would be much appreciated Report
May 21, 201610 yr comment_8824 G'day, ZD30 (engine in Y61 or Patrol) with automatic is better choice then with manual in most situations except downhill runs in off road scenarios. Engine is well matched to the auto box and unless there is a particular reason for wanting to manually steer the stick go for it. Cons: *only 3 speed plus overdrive, *torque converter lock up clutch system control (it should lock up torque converter sooner >80 km/h and in every gear) however that is easily fixed with aftermarket modification. *downhill braking is non existent unless above is applied or additional heavy duty shift control is installed big which is $$$ * not user maintenance friendly *expensive to repair Pros: Easy driving around town Great in sandy/soft surfaces conditions Regards Report
