October 25, 201610 yr comment_8932 Hi guys, I am after some feedback on fitting an oil catch can to the y62. Does anyone have one installed and if so can you give some recommendations on brands.Thank you Report
October 29, 201610 yr comment_8936 G'day, I'm not sure catch can is the required idea on petrol non turbo charged engine. Because the suction is limited and so is compression ratio the engine, not subject to greater internal crankcase pressure necessarily. Having said that you can try but I'd would not even entertain an idea of Supercheap or Autobarn style catch cans. Simple rocker cover oil trap Nissan has included should be sufficient but sadly it usually isn't. I'd go with the pros from MANN company and get Provent Regards Report
