ShaneOwnsANissan Posted October 4, 2018 Report Share Posted October 4, 2018 Hi all, 2001 3L DDI When driving I'm getting the "0707 Injection Pump injection timing control" code and the car loses power. If i turn the car off for a few seconds and turn it back on I then regain power and the engine light turns off. Pressing the manual prime pump, it feels soft and I can press it a few times before going hard again. My questions: 1. Would the soft prime pump indicate air in the line? 2. If so, would this mean the air is coming from before the filter/the filter itself e.g. does the pump have a diaghpram which prevents air coming back from further up the line? I had this error the day before, thinking maybe bad fuel, put 60L and injector cleaner and the error didn't appear for 100km.Due to the prime pump being soft, I'm thinking maybe just coincidence or perhaps i have a small air leak but the main issue is bad fuel quality? Regards, Shane Link to comment Share on other sites More sharing options...
Rumcajs Posted October 5, 2018 Report Share Posted October 5, 2018 (edited) G'day, 1. NO, because it is on the suction side and if it only takes several presses and it goes hard then that is normal behavior. 2. Yes, you can have air entering from the priming pump diaphragm Use of injector cleaner create sometimes more problems then it is worth. Did you change fuel filter as well? If you did, it is possible that the filter installation is not correct and it is bypassing the sealing or that extra "O" ring everyone ignores..... Anyway, this is a dreaded fault for anyone "lucky enough" to own vehicle with that abomination made by Bosch the VP44 radial injection pump. What you should really do is to check ICV % via Nissan "datascan" or ECU talk software and Consult cable while engine is running. Anything less then 35% duty cycle at idle indicates issues with fuel delivery to the pump. It should be around 50%-70% under load and on deceleration even higher. To identify issue with air in the fuel is very difficult. You will need to ensure that fuel lines are sound including steel lines and pick up in the tank. That's why it is essential to be able to compare ICV% values/readings as you perform diagnostics. * Change fuel filter in case it is blocked with what cleaner has created and bleed the system thoroughly first if you can. * Check/Decide if running new fuel lines and hose clamps might fix the issue *If problem persist create/make temporary clear see through fuel lines/hoses running from the pipe in the chassis to the filter and from filter to the pump so you can visualize what air if any is coming in. * if still there run the lines from spare jerry or bucket filled with clean diesel fuel to eliminate fuel lines leading to fuel filter depending on above step. * Depending on the outcome of previous checks try another fuel filter housing to eliminate priming pump diaphragm if the air in the fuel is still present. * If the problem persist it is possible that the injection pump is failling and the big bill is coming your way. If you have access to compressed air and are handy with creating temp blanking plugs then I'd disconnect the fuel line from the injection pump, blank its end and then disconnect line at the tank and pressurize the line with max 75-85 kPa and check for air leaks. That will tell you quite quickly if there is an issue with the tightness of the system. Also don't discount possibility for fault in the electrical harness on the pump. Good luck Edited October 5, 2018 by Rumcajs Link to comment Share on other sites More sharing options...
ShaneOwnsANissan Posted October 6, 2018 Author Report Share Posted October 6, 2018 Wow, Thanks foir the detailed reply Rumcajs! I haven't yet changed the fuel filter however the previous owner said they did it right befoire i bought it, so thinking it could be a possibility. I've changed the majority of the fuel lines however the smaller line, it looks like i tightened the hoseclamp too much and it has a slight seep from the clamp. I'll start with the fuel filter as I've already bought a replacement and then look at the other suggestions. I'll update the thread with what the fix is. Thanks, Shane Link to comment Share on other sites More sharing options...
ShaneOwnsANissan Posted November 18, 2018 Author Report Share Posted November 18, 2018 For anyone Following this topic; I changed the Fuel Filter and since, have not had any '0707 Injection Pump injection timing control' codes.It appears the fuel filter was over-torqued and the O-ring was was crushed which likely allowed air to be sucked in. Link to images showing Crushed O-ring and Filter contents:https://imgur.com/a/yOrUbqb Video showing how easily the filter O-ring would fold over where it appeared to be over-tightened:https://youtu.be/pqd6yAi9jB4 Link to comment Share on other sites More sharing options...
Patrolherb Posted February 26 Report Share Posted February 26 2002 ZD30DI i have had a priming issue for a while approx 3-6months sometimes I would have to manually prime today it won't prime at all so won't draw diesel into the filter the truck was running fine yesterday,now I can't even get it to prime im assuming it's just the primer but was wondering if it could be something else Link to comment Share on other sites More sharing options...
