March 2, 20197 yr comment_9221 I need a Patrol guru... Ok firstly hello to all, some probably know me from the other forums. Ok a fast recap of my machine and then to get to my problem.I drive a DI 2004 Patrol it has never missed a beat. Yes the mileage is high now @ 280000miles (450000k's) all that was ever done was the clutch and solid flywheel conversion.So recently i came home from work and i had no engine lights, nothing wrong, pulling a good load of timber behind.Great power... well maintained Patrol. Never misses a beat and so i came home and switched it off,went in and had some lunch (probably one hour gone) and returned to go back to work and a NO START....cranking over but nothing... STRANGE... Ok so ahead are the things i have done but it is hell cause i'm getting no codes. 1/ I bridged the terminals 8 & 1 to get codes, i kept getting 0505 which is no faults detected!!! 2/ Took of fuel filter put on a new one with freshly filled diesel, got a good prime on the lift pump...NO KICK. 3/ Opened airbox used some starting spray GOT A KICK... trying to start. 4/ Done more diagnostics and got a code 0403 (Throttle position sensor) 5/ Changed throttle pedal and sensor (Still no START) 6/ About to change the CAS now I really don't mind putting money in to my Patrol,i suspect the IP as a possible failure too but i'm not sure what to change/check simply as i am getting no damn fault codes Any suggestions before i go mad!!! LOL ... Regards Dan Report
March 3, 20197 yr comment_9223 G'day, I don't know what is CAS! Argh, the acronyms Crank Angle Sensor ..... If main ECU claims no faults then you have to flash out codes from the pump ECU....... However, ZD30 are also known not starting if the cranking RPM are lower then expected.....I think that one applies to CrD more likely. There is a chance that pump ECU is not powering up so check that battery voltage is present at appropriate terminals and that ground connection is also sound. There is a guide on the net on howto force the IP ECU to power up in emergency and fire up the engine in the idle mode only. Here ===> https://www.bluechipdiesel.com/runningtests Bear in mind that these are for North Amercian 6 cylinder version of VP44 however the underlying method is corect as 6 cylinder version only difference is in the distributor and pumping element. Control side is identical apart from no external lift pump circuit on Nissan. Also ensure that wiring connections listed are as on your Nissan by checking wiring diagram in the Nissan manual which by now any selfrespecting Patrol owner should have already aquired. I'd also not discount the fact that NATS might have something to say about that too. Have your tried your spare key? Regards Edited March 3, 20197 yr by Rumcajs Report
March 3, 20197 yr Author comment_9224 Hi thanks for your help. Firstly to investigate NATS or anything else at this stage i need to take Patrol to autoelectrician who already i talked through all the checks i done with NATS and the dash lights that it works with and everything was well and i was advised to take it to a mecanic as he said if it was kicking with starting spray it couldn't be something electrical. (His opinion) sure wouldn't you think that starting spray would fire anyway in any tight combustion chamber. I'm not convinced that using starting spray in the airbox shows us anything at all. Here is what i'm faced with and what i have done so far. 1/ Anyway, the real problem now is with no fault codes my options are running out. Should i take it to Nissan as there is a garage in the next county. The problem is it will cost me 80euros for a diagnostic check (Min cost depending on time spent at it) or with no codes present will they be able to tell me either what's wrong?? The tow truck and diagnostic day with nissan may not stop at 300euros! This is before the Patrol gets touched to be repaired at all 2/ Should i try the CAS sensor?? would it be worth changing out.. List of what i have done -Changed and primed a new Diesel filter (NO KICK) -Checked NATS with both keys (NO KICK) -Checked NATS light on dash by removing chip from key and trying to start (SOLID RED LIGHT STAYS ON DASH) -Used a made up funnel direct to IP (NO KICK) - Sprayed starting fluid in to airbox (KICKED,TRYING TO FIRE) I just don't know what to do next, my mecanic advised me on the phone it was the IP but this involves a tow truck and getting the Patrol to him, then is it going to be the IP after all that...why the hell is the stupid machine not giving me fault codes!!! lol Dan Edited March 3, 20197 yr by Dan Ahern Report
March 7, 20197 yr comment_9228 G'day, IMHO it is the injection pump part. If only you had diesel injection specialist around who has Bosch scanner which will read internal pump ECU codes. That is the only fool proof way to identify if it is injectiom pump control circuit. Apparently someone was able to make his own DYI scanner. I had a link to it in the past..... If there is anyone to blame for this fiasco it is Bosch and the shyte they did where allegedly the stole this idea of radial injection pump and messed it up big time. VP44 is throw away design for which those responsible should be shot honestly. The story of Bosch VP44 epic fail is legendary, be it States, or in the UK most repair shops should be very familiar with it as it was very common in diesel powered Vauxhals/Opels/Audi etc of the late 90s early 00s. Japs bought in to it with Zexel and here we are with Nissan. Biggest killers of these pumps are heat and fuel starvation. Regards Report
September 29, 20197 yr comment_9782 On 3/3/2019 at 10:28 PM, Dan Ahern said: Hi thanks for your help. Firstly to investigate NATS or anything else at this stage i need to take Patrol to autoelectrician who already i talked through all the checks i done with NATS and the dash lights that it works with and everything was well and i was advised to take it to a mecanic as he said if it was kicking with starting spray it couldn't be something electrical. (His opinion) sure wouldn't you think that starting spray would fire anyway in any tight combustion chamber. I'm not convinced that using starting spray in the airbox shows us anything at all. Here is what i'm faced with and what i have done so far. 1/ Anyway, the real problem now is with no fault codes my options are running out. Should i take it to Nissan as there is a garage in the next county. The problem is it will cost me 80euros for a diagnostic check (Min cost depending on time spent at it) or with no codes present will they be able to tell me either what's wrong?? The tow truck and diagnostic day with nissan may not stop at 300euros! This is before the Patrol gets touched to be repaired at all 2/ Should i try the CAS sensor?? would it be worth changing out.. List of what i have done -Changed and primed a new Diesel filter (NO KICK) -Checked NATS with both keys (NO KICK) -Checked NATS light on dash by removing chip from key and trying to start (SOLID RED LIGHT STAYS ON DASH) -Used a made up funnel direct to IP (NO KICK) - Sprayed starting fluid in to airbox (KICKED,TRYING TO FIRE) I just don't know what to do next, my mecanic advised me on the phone it was the IP but this involves a tow truck and getting the Patrol to him, then is it going to be the IP after all that...why the hell is the stupid machine not giving me fault codes!!! lol Dan Hi we had the same problem with the GU Y61 TDI . we changed the fuel pump $2500 ( no fire ) we changed the glow plugs $125 ( no fire ) then my father lost all his keys Nissan wanted $1500 to transport the Nissan 450ks to there shop and also wanted $400 per key I brought the id41 chips and a few keys and programmed two keys to the y61 after programming the keys I thought I would wind it over all of a sudden it started first kick every day for 3 weeks now it has started first kick ever time . You might have the same problem hope this helps Report
