November 11, 20206 yr comment_10766 Hi all - I'm trying to find out the expected oil pressure on a 3.0TD engine. My oil light came on the other day and since then I've replaced the oil sensor near the turbo and oil resistor in the cab. I'm waiting on the correct oil sensor near the starter to arrive. Despite changing the above and unplugging the sensor near the starter, the oil light still lights up once the engine is running. I've just put the oil pressure gauge on the top sensor unit bear the turbo and the readings I'm getting are: Idle = 85/90 PSI or 6 Bar Rev to 2,000 = 100 PSI or 7 bar Rev to 3,000 = 115PSI or almost 8 bar Are these figures ok or is it running high? Cant find any definite figures online for this engine, so appreciate you're help. Thanks Report
November 14, 20206 yr comment_10810 Oil pressures look fine, however which model year is yours? If it is 2007 onwards then ECM is measuring the actual oil pressure from RHS unit. Oil Pressure is monitored via the ECM with the utilisation of an Oil Pressure Sensor which is located at the RH rear of the engine. In addition to the Oil Pressure Sensor there is an Oil Pressure Switch located at the LH front of the engine, above the oil filter. This switch will ground & illuminate the ‘red oil can’ warning light when there is close to 0 Oil Pressure. The above mentioned Oil Pressure SENSOR is connected directly to the ECM. If the ECM measures specific pressures at certain engine speeds & temperatures, the ECM will signal the Instrument Cluster to illuminate the RED OIL CAN warning light on the Instrument Cluster. Regards Report
February 3, 20215 yr comment_11005 Oil pressures look fine, however which model year is yours? If it is 2007 onwards then ECM is measuring the actual oil pressure from RHS unit. Oil Pressure is monitored via the ECM with the utilisation of an Oil Pressure Sensor which is located at the RH rear of the engine. In addition to the Oil Pressure Sensor there is an Oil Pressure Switch located at the LH front of the engine, above the oil filter. This switch will ground & illuminate the ‘red oil can’ warning light when there is close to 0 Oil Pressure. The above mentioned Oil Pressure SENSOR is connected directly to the ECM. If the ECM measures specific pressures at certain engine speeds & temperatures, the ECM will signal the Instrument Cluster to illuminate the RED OIL CAN warning light on the Instrument Cluster. RegardsHi Rumcajs,So the best place the to tap the after market oil pressure guage is on the RHS sensor near the start?Cheers,Sent from my iPhone using Tapatalk Report
February 3, 20215 yr comment_11006 Well technically yes that would be correct however it is a very tight spot to fit aftermarket sensor in there if there is already one fitted (Series 4 onwards). Regards Report
May 18, 20224 yr comment_11747 Hi, what did you end up finding was the problem , I have one with exactly the same symptoms and oil pressure, over 100psi at idle !! desperatly need help ! Thankyou in advance! Report
