May 10, 201214 yr comment_1252 Well hi all I have a 2.8td GU it's my first patrol but not my first 4wd I'm a mechanic by trade and a brake and clutch specialist however I'm working in the mining industry at this time and all going well will be going back to doing an apprencship as a fitter machinist Having access to all the catalogs I do when I get a second or three I might put together a list of part numbers for parts that fit the different models thinking I'll start with brake parts first then other areas Report
May 10, 201214 yr comment_1260 Welcome mate. Please share any and all info that you have. We have alot of catching up to do on here. Report
May 10, 201214 yr comment_1269 Welcome, I am also in WA That would be really handy having a catalogue of the braking parts available on the forum Would be great as a sticky in each different models forum Report
May 10, 201214 yr Author comment_1320 I'll get in to it in the next few weeks then it will be a big sticky once you take all models with different hoses caliper kits etc Report
May 17, 201214 yr Author comment_2787 Well I started work on it I thought bugger it and have put it on an excel spread sheet with every other number I can find what I'm hoping is anything I miss can be added by other member and it made a sticky in its own heading just for part numbers of after market parts that fit your model so far I have all the brake clutch and coolant hoses and filters belts plugs both types of fuel anything else to add to that before I start putting in number Report
