TaffWest Posted March 25, 2013 Report Share Posted March 25, 2013 The Flywheel on my 2008 CRD seems to be groaning at certain RPM under load (vibration-noise). Everything has to get pretty hot before the issue becomes obvious. I will have to change the flywheel and the clutch at some time in the future and i wondered if anyone had fitted a single (solid) mass flywheel instead of the standard dual mass flywheel. I believe there are some trade offs. Do the benefits outway the negatives? Would anyone recomend fitting the solid flywheel? Cheers TaffWest Link to comment Share on other sites More sharing options...
Rumcajs Posted March 26, 2013 Report Share Posted March 26, 2013 (edited) I'd fit solid flywheel and HD clutch instead of DMF and Nissan's excuse for a clutch right away. The benefits far outweigh the negatives but again it depends on how fussy you are. The main benefits/reasons for DMF (Dual Mass Flywheel) are: Reduced vibration in the motor and the driveline Torque/shock loads dampening on the transmission (less attention on clutch engagement habits) all these are excuse for cheap lousy engineering and shortcuts to save money at the expense of the customers. The main negatives reasons for DMF are: Expensive Weak Limited service life Unreliable Solid flywheel conversions Negatives: Vibrations at low RPM under load Harsh torque/shock load on the driveline (more attention on clutch engagement) Positives: Cheaper, Long term service life Simplicity Reliable Repairable Cheers Edited March 26, 2013 by Rumcajs Link to comment Share on other sites More sharing options...
BigGQWesty Posted March 26, 2013 Report Share Posted March 26, 2013 X2 on solid. A bit more costly to I think to change over, but once done its cheaper in the long run.. Kallen Westbrook Owner of Westy's Accessories Link to comment Share on other sites More sharing options...
TaffWest Posted March 26, 2013 Author Report Share Posted March 26, 2013 Thanks Guys Link to comment Share on other sites More sharing options...
Fathom Posted March 27, 2013 Report Share Posted March 27, 2013 Yup I changed mine to SMF too. Have had no complaints. Link to comment Share on other sites More sharing options...
matthewperk Posted April 12, 2013 Report Share Posted April 12, 2013 Mine is single too. Definatly notice low rpm vibrations, but all that means is that you should probably be shifting down a gear anyway!Sent from my GT-I9300 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Bogmeister Posted April 26, 2013 Report Share Posted April 26, 2013 My Di is SMF. My CRD will be when it needs replacing. Link to comment Share on other sites More sharing options...
