May 5, 201313 yr comment_7244 Hi guys, I have come to my senses and got a patrol. Very happy with it. 2003 ZD30 165000 with all the fruit. Can't wait to get it off the black top. My name is Dave and i am Sydney. See you soon guys. Cheers Dave Report
May 6, 201313 yr comment_7247 Hi Dave, welcome to the forum. Sounds like you got the better deal this time, just make sure it has all the important mods in regards to ZD30 NADS. Cheers Report
May 6, 201313 yr Author comment_7250 first thing on my list. Will start with boost, pyro gauges and EGR block. Then will do catch can, dawes valve and needle valve. Already have a 3 inch zorst. Cheers Report
May 7, 201313 yr comment_7252 first thing on my list. Will start with boost, pyro gauges and EGR block. Then will do catch can, dawes valve and needle valve. Already have a 3 inch zorst. Cheers If I can suggest the order than: 1. catch/oil separator can 2. Pyro gauge 3. Boost gauge 4. Dawes and needle valve 5. EGR shim Remember ECU uses EGR to a degree to control boost so if blocked it will send boost sky high so to speak. You need to control boost first. Cheers Report
