May 29, 201313 yr comment_7316 My gq tb42 motor is over revving. What happened is I just started my car up in the cold and drove it easy up the road then I put the accelerator further down and it started coughing and splattering obviously cause the automatic choke was still on. Strait after that it just revved out and I've checked the throttle which doesn't seem to be stuck. Any ideas would be greatly appreciated? Report
May 29, 201313 yr comment_7317 Define over revving. Is it like going to max revs on its own or is it increased idle speed.... Cheers Edited May 29, 201313 yr by Rumcajs Report
May 29, 201313 yr comment_7319 Looks like you've got carby stuck in max position. take the intake pipe off and have a look if you can see throttle flap closed, than see if you can operate it manually. Cheers Report
May 30, 201313 yr Author comment_7323 It was stuck in max position but all fixed now. Thanks for your help Report
