December 26, 201312 yr comment_7679 Has anyone had similar problems with engine ping under load on petrol, if so any suggestions how to fix it. we have had the injectors cleaned, but then the noise returned after a week of town driving. Report
December 26, 201312 yr comment_7681 Sorry, can help you much with petrol engines but the pinging would suggest that either the timing is not working correctly or you are using low octane fuel. Which year is your? If you try premium unleaded (98 Oct) will the pinging stop?You could also try adding something like octane booster in to the tank to see if that makes any difference. Cheers Edited December 26, 201312 yr by Rumcajs Report
January 1, 201412 yr comment_7690 If the eengine is tuned to gas it'll ping on petrol. If tuned to petrol it'll ping on gas. It's to do with the advancing of timing between to 2. So you need a tune and get it tuned to middle of both fuels.Kallen WestbrookOwner ofWesty's Accessories Report
December 20, 20169 yr comment_8962 yes what Westy said so on petrol your manual will say 15 deg btdc +or- 2deg .and when you accelerate the timing will advance to suit the rpm. now on gas this setting is some what gutless so the timing is advanced even more say up to 20 deg btdc now add load when accelerating your timing can be 25 deg btdc grate for lpg not so for petrol so what i have done is the tune for gas because this is my daily driver and and only use petrol out on the hwy say at 100kmph a few times a week to keep it running well.LPG is quite punchy around town at the lights stopping and starting so no worries there and lpg is still cheap around 90 cents a liter. can,t complain about price ether. so what about 4x4ing i use LPG less nasty exhaust gas to breath when attaching the snatch strap for recoveries and engine don't starve of fuel when things get steep or of camber. hope this helps you out there happy 4x4ing Report
