May 2, 201412 yr comment_7852 Help I just cant work it out I have a problem with the front of one of my safs done wheel bearings and seals and noise is still there when im driving at 80-100kmph and take my foot off the gas im getting a grinding wearing noise from frount end no wobble at all or vibrations bearings are tight not over tightened either sound like diff area but then feel a lil rattle in bottom of footwell and end of grinding noise its doing my head in a bit my other saf has same mods and works fine Any help would be mush appreciated Report
May 2, 201412 yr Author comment_7856 Manual locking hubs got superwinch ones on my other truck might swap them over and have a look and see if that fixes the problem Report
May 2, 201412 yr comment_7857 Have you tried just locking them to see if the noise changes. Normally noise when backing off is a sign of diff trouble but this being a front one which is normally not driven one wouldn't have thought that it is a problem. Unless this noise happens 4WD mode. Cheers Report
