May 29, 201411 yr comment_7908 hi there I am seriously looking at buying a 2001 gu II patrol with 280000kms dont think anything has been moded to the engine can i get a few year out of it before it goes BOOM Report
May 30, 201411 yr comment_7909 You are buying worn out used car, its engine can expire anytime. Unless you are getting it extremely cheap and you are handy with spanners stay away. Cheers Report
June 1, 201411 yr Author comment_7911 yeah got it for 10G with 35 inch tires roof rack 2inch lift for better or worse got it has not had anything done to engine it runs nicely sholud i do any of the nads or just wait for the boom done 291000ks starting the grande fund now Report
June 2, 201411 yr comment_7912 Oh well, now you've got it may just as well fix the NADS to it. Not that expensive and Dawes and needle valve will transform it for better. Cheers Report
January 22, 201511 yr comment_8228 ive got same model, 200k on odo, same thing, no mods done. has service history and all seems fine. with a diesel i expect to double the odo, it will either continue to run without blowing up or it wont, it is not a garuntee that all engines that have not had nads done will blow up, its actually a small % that have considering the amount that have been sold here in Aus. like all vehicles, some run for ever some dont Report
