November 13, 201510 yr comment_8644 Hi guys were is a good spot to pick up the (+) dash light on the GU? Iam install a rocker switch. Cheers paul Report
November 13, 201510 yr comment_8645 Most switches on the dashboard would have one you can piggy back on to. Wiring colour is usually dark blue and black tracer. If you really desperate use the illumination for/from the ciggie/accessory 12V socket. Regards Edited November 13, 201510 yr by Rumcajs Report
November 13, 201510 yr Author comment_8646 Thanks for that mate ill check it out in the am. paul Report
November 13, 201510 yr Author comment_8647 Got it off the rear aircon switch right as usual dark blue and black tracer thanks for the help champ. couldn't wait for am. Report
