I’ve seen a bit of excitement lately about SSDs vs Hard Disk Drives on many of the tech sites/forums, especially since the price of SSDs have been falling and capacities have been increasing, though nowhere near the $/GB factor of traditional spinning platters. I've also been hinting at backup and recovery options in some recent posts and noted Linux as being a good option should things go wheels up on your PC. However, that only provides you with a way to recover data and not your operating system (OS) and programs that you may have installed on your PC.
If your PC goes wheels up, you may be able to recover your OS, but you're usually going to have to re-install all of your programs from scratch. And if it's a complete hard disk failure, then it can be a painful process, one which I've experienced twice so far in 30 years, which is twice too many. So what can you do? The solution is actually quite easy and not all that expensive considering the pain that you can avoid. Hard disk drives are pretty cheap nowadays, so you can afford to have at least one spare, acting as nothing but an image of your working system. I did just that the other day with my PC hard drive, as I have several 1TB hard drives lying around, so rather than let them languish, I thought I'd use one of them to create and store a complete image of my main PC. There are many ways to do this and even Windows gives you an option, but they aren't quite the best. I also wanted to do the same with my Gigabyte tablet, as I'd hate to have to rebuild everything from scratch, but I didn't have a spare 7mm form-factor hard drive.
To that end, a search through the local PC hardware sites (http://www.pccasegear.com/index.php, http://www.cplonline.com.au) gave me some options. I could get a suitable 500GB hard drive for $100, which was way overkill as far as capacity went or a 128 GB SSD for $130. So I thought I'd try out the SSD, since it was more than enough for what I needed and wasn't that much more than a regular hard drive, but what to get? By the way, I did a search on eBay and no one had prices that could match the two stores. A lot of research narrowed down the selection to three options, an Intel 520 120GB, an Intel 330 120GB or a Samsung 830 128GB SSD. The Intel 520 was reportedly the best SSD on the market at the moment, ie speed and reliability etc; with the Intel 330 close behind, but with performance hobbled to some degree to keep the price down. The Samsung 830 wasn't as fast as the Intel SSDs, but not far behind the Intel 330 and all reports I could find gave it a very high score as far as reliability. The Intel 520 was about $50 more than the Intel 330 and Samsung 830.
One thing I found from my research is that consumers SSDs, then cheapest variety, have tended to have quite a record of failure compared to regular hard drives; surprising really, considering that there are no moving parts. What apparently is the Achilles ’ Heel of SSDs is the controller and most SSDs use a SandForce controller, Intel included with the 520 and 330, and the controller can cause all sorts of issues causing the dreaded BSOD and even complete SSD failure. The SandForce controller is a generic controller sold to many SSD manufacturers and it's up to them to make sure it works properly with their SSDs. But these manufacturers don't necessarily work closely with SandForce, so their efforts at solving issues aren't always effective. But what Intel has done is work very closely with SandForce and modified aspects of the controller to improve the reliability so that they are confident about its long term performance; only Intel has access to these modifications. Samsung, on the other hand, make all their own components and so they all work in concert and don't rely on third parties.
Another aspect of SSDs is the need to regularly ‘clean’ the drive of ‘garbage’ that accumulates during read/write operations. With the Intel SSDs, and just about all the others that use SandForce controllers, this cleaning is done on the fly, which may reduce the overall performance of the SSD, but keeps performance consistent all the time. With the Samsung, the cleaning is done during quiet periods, which means that in intensive operations, the performance can drop significantly if cleaning is not able to be done. This can be a concern in data centres and where you are really making the SSD work for long periods of time on intensive tasks; something to consider when choosing an SSD. However, since my tablet was not going to be used in intensive tasks, I decided to go with the Samsung 830 128GB SSD for some reason. Maybe I was just a bit worried that despite the work that Intel had done with their latest SSDs, and favourable reports, they haven’t really proved themselves regarding long-term reliability. Anyway, the SSD arrived yesterday and it was time to clone the OS.
In order to clone a drive, you need to be able to connect the drive to the main PC and what I used was a SATA docking station that I’ve had for some time. This device enables you to insert a 2.5” or 3.5” SATA hard drive and connect it via a USB cable to any PC, a simple and elegant solution. The cloning process is actually quite easy, depending on what you use and my recommendation is to use software designed for this purpose. The Samsung came with an option to download Norton Ghost, which I had some reservations about, but decided to try anyway, since it was what Samsung offered. I thought that Norton Ghost would be on the disk provided, but it was actually available as a download, which I accessed through the Samsung SSD Magician software that I’d installed (more on that later). After downloading and installing Norton Ghost, I started the cloning process only to discover that what I’d downloaded was a 30 day trial version, but with the ability to do the clone. Also, as soon as I opened the program, it wanted to make all sorts of changes to my tablet. My suspicions had been vindicated. So I did a complete system restore to get rid of Norton Ghost. That fully confirms all of my previous views that anything that comes out of Symantec should go straight into the bin.
Anyway, I had a program already installed called Paragon Hard Disk Manager (http://www.paragon-s...me/hdm-personal), which allows for the migration of everything from one hard drive to another, as well as many other functions, and is what I’d used to clone my PC hard drive. I should have used this from the outset, but then I wouldn’t have had my confirmation of the Symantec rubbish. I also have another similar product, Acronis, which came with a laptop that I’d bought years ago, but I never became wedded to Acronis, as it had what I thought was a very obtuse interface. A lot of people swear by it, I just swore at it. Anyway, I discovered Paragon and when I bought it in 2010, it was pretty inexpensive and even the latest version is reasonably priced.
When cloning an SSD, using a dedicated program designed for this can be important, as an SSD works differently to a regular hard drive so it’s important apparently to match everything from one device to the other, including sectors or whatever from one drive to the other (Google cloning hard drives to SSDs and you’ll find out). There are differences in how both work devices work and if they aren’t matched properly, you can get all sorts of problems. Anyway, the cloning worked flawlessly and when I swapped the two drives in the tablet, it fired up as if nothing had changed. And that’s exactly what made me wonder what was going on, things should have been blistering fast for start-up etc, but they seemed to be much the same as with the normal hard drive. So once everything was confirmed to work, I opened the SSD Magician software to see what it would do.
The SSD Magician offers a range of disk and OS management and optimisation functions, so I went through all of these and selected the recommended options. I also did another Windows performance test and all that increased was hard drive data transfer rate figure from 5.7 to 7.7, everything else obviously stayed the same. So with further testing by opening and closing programs, shutting down the tablet and restarting once again, I can say that the SSD hasn’t measurably sped up many of the functions on the tablet. Some programs do open faster, such as Lightroom and Photoshop, but these are really are the most intensive of programs one can use and are usually quoted when SSDs are compared to regular hard drives. One program that does work a lot faster is Memory Map, not so much when opening, but loading maps is significantly faster, so I guess in these types of operations you can see the improvements.
Why doesn’t the SSD significantly improve performance like you so often hear? Well, I think it’s due to several factors. Firstly, the tablet isn’t a speed demon from the outset, so the hard drive isn’t the performance limiting factor that it can be on very high performance desktop PCs. Secondly, the original hard drive wasn’t a complete slug and by using Ready Boost, I was able to get pretty good performance out of the drive and associated operations. Thirdly, some things simply won’t work faster with an SSD, as they are dependent on accessing stuff on the net or network.
So is an SSD worthwhile? In a desktop environment, all the indicators are that SSDs can be very beneficial, especially if you put your OS and programs on the SSD and data elsewhere, but in my example and similar situations, you’re not going to get mind blowing results by installing an SSD. Power consumption, ie improved battery performance may improve, but I haven’t had a chance to measure this. If you need a lot of hard disk space, then a regular hard drive is, in my view, the better way to go, especially if you have space in your device for only one hard drive. I certainly wouldn’t have contemplated this even a year ago, as SSD prices were incredibly high compared to regular hard drives, but in this case it was worth a try.
Ray
