January 5, 20188 yr comment_9107 hey I lost tacho ac coldness and glow other day driving to work have checked wires and pretty sure all fuses where good anyone had this happen and if so what was the problem thanks. Report
January 7, 20188 yr comment_9109 G'day, You need to give more information. Especially about which engine is in yours as I'm assuming it is 2006 GU. That means 2 possibility, ZD30, TD42Ti I'm guessing TB48 doesn't have glow plugs. Regards Edited January 7, 20188 yr by Rumcajs Report
January 7, 20188 yr Author comment_9111 even with the extra info about motor no comments ha ha thought it was going to explode the post after i put what motorit was Report
January 7, 20188 yr comment_9112 There should be fusible links and fuses box in the engine bay next to battery on RHS. Check there, glow link is 100 Amp, and cooling system is 40 Amp. Regards Report
