May 4, 201214 yr comment_593 Hey, first start of the day the engine turns over really slowly, starts after around 1/2 a turn though. After the first start of the day it cranks freely but takes a few turns to start. What would cause this? Sent from my iPad using Tapatalk HD Report
May 4, 201214 yr comment_607 First start issue, battery for suregt it checked, winder brings out the worst in a tired battery Extralong crank time: firstly suspect glow plugs worn- would stat with new glow plugs. but this fault still could be related to a fulty battery so would stick with battery testing to startwith, if u get a new battery see if it fixes ur cranking issue to if not, glow plugs Report
May 4, 201214 yr Author comment_643 I shall check but battery isn't that old and has never been run down Straight with BALLS!!!! Report
May 4, 201214 yr comment_648 Still would be very sure it's a battery issue, it going flat is different to being faulty so that doesn't mean anything, like I said the start of the cold weather brings out battery issues big time, so if it's oly happened for the last month or less then I'm quite sure it's a battery pro, but yeah get it checked properly before u replace it Report
May 6, 201214 yr comment_793 Give it a full on bench charge, I do all my Batts. roughly 6 weekly!! Report
