May 13, 201213 yr comment_2027 Just a bit of a list of what's been done over the last couple of years. As you can see it's been set up for long distance touring. 90 Series Heavy TrPATROL 2'' lift with Koniack Raid snorkel & 10" dust spinner 33''MTZ's x 6 twine shower 9.500lb Mako winch Uhf TX3400 GME AE4705 Uhf Electrophone aerial Pioneer MP3/CD radio Offroad 3 Draw System with fridge slide Redarc 1220 3 stage duel battery charger 150lt main fuel tank 70lt sub tank 60lt water tank Kaymar rear bar with duel wheel carrier & rear work light with 3way switching tripple battery's 40lt engle fridge Arb steel roof rack wind deflector full length roof bag steel Bullbar IPF 930 100/170 driving lights Diff Breathers endless air compressor arabian tail lights Recovery gear window tinting 300w inverter Fire extinguisher head light protectors rear air deflector side shovel mount with shovel 3" exhaust + 3" dump pipe ARB sidesteps & brush bars ARB side awning 3.9 diffs changed to 4.3s Plus 5 thou shim Draw system with 3rd battery. 60lt Water tank fitted A bit of flexing Water hazzard. [iMG]http://i37.photobuck...ol Photos/3.jpg Report
May 13, 201213 yr comment_2044 Hi nice rig but that thing would have to be overweight mine comes in just on 3 ton yours would be way more by your list Alan Report
May 13, 201213 yr comment_2060 That is an awesome setup mate. Could you post a few pics of the twine setup if not to much trouble. Cheers. Report
May 14, 201213 yr Author comment_2096 Hi nice rig but that thing would have to be overweight mine comes in just on 3 ton yours would be way more by your list Alan Yeah, It's about 3.3t with little fuel. Thats why I'm running the big Koni shocks and Poly bags. Report
May 23, 201213 yr Author comment_3486 That is an awesome setup mate. Could you post a few pics of the twine setup if not to much trouble. Cheers. Heat exchanger on the fire wall. In let & out let Report
May 23, 201213 yr Author comment_3488 Fitted some lights to the rear doors supplied by this bloke on Ebay http://www.ebay.com.au/itm/270961586205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Only involvement as a happy customer. Report
May 23, 201213 yr comment_3508 Heat exchanger on the fire wall. In let & out let Hot coffees or hot showers? Were from and how does it work,, Report
May 23, 201213 yr comment_3512 Where did you get the water tank from? That's what I've been after to fill in the empty void & keep the weight down low. Report
May 23, 201213 yr Author comment_3515 Where did you get the water tank from? That's what I've been after to fill in the empty void & keep the weight down low. The tank was fitted by http://www.offroadsystems.com.au/ They also did the draws. Report
