April 17, 201313 yr comment_7202 Hi guys, Anyone know enough about the sub tank system on the GU so I can get rid of the darn instrument cluster LED warning? I've removed the transfer pump (because I don't need it) and it now has illuminated. Obviously it's smart enough to know it's gone. Will disconnecting the controller unit inside the centre console going to work? Any better ideas? Cheers Report
April 18, 201313 yr comment_7203 I wouldn't do that as the controller is also in charge of the main tank level gauge. I'd try disconnect the wire from the controller to the display light, pin 13 that should take the light out. Cheers Edited April 18, 201313 yr by Rumcajs Report
April 18, 201313 yr Author comment_7205 Great idea that. I will hunt down the connector/wire to 13 on the controller. Thanks very much! Report
April 23, 201313 yr comment_7217 Pull the bulb out. If it is an LED inside the instrument cluster you technically cant. Report
May 1, 201313 yr Author comment_7233 There is a small piece of black electrical tape over it at the moment Report
