GU3 steering wheel
Has anybody put a sports steering wheel on a GU3, and removed airbag ,all is easy till you come to the clock spring, Not sure on how to either remove or ,leave to get horn to work?
It is illegal to tamper with SRS equipment/remove steering wheel airbag, as for the clock spring there shouldn't be issue finding out correct wires and tap in to them for horn buttons. SRS Airbag cable is ussually in it own armored cable/clock spring and horn buttons on their own.
I'm not sure how it is on Patrols though.
Airbag related wiring is always wrapped in bright yellow sheathing as well.  This should be on the bag, under the dash and on the sensors.
