January 14, 201511 yr comment_8222 Sorry people im only new to this, i have a 2010 gu st wagon, the tailights are not working either is the cruise control and the transmission lock, have checked fuses ans globes,??? Any ideas Report
February 8, 201511 yr comment_8244 It will more then likely be a blown stop light fuse causing all 3 problems. The stop light fuse is fuse number 14 in the fuse box inside the vehicle. It's a 10amp fuse. If the fuse is blown you will need to find the cause. Start by checking the trailer plug and it's harness for possible damage. Report
