May 12, 201214 yr comment_1860 Thought my Wagon needed a thread! haha Here it is Its a 2000 ZD30 GU, I thought it was a good buy had done 210,000km but had a rebuilt engine 20,000km before so heaps cheaper than buying one with a few less kms but having to rebuild in a few more kms. Anyway, it came pretty much standard apart from electric trailer brakes, UHF and a hyclone. <=Awesome ... not! Then added: 33" BFGoodrich KM2s Procomp Alloy Wheels Steel Genuine Bullbar Pioneer Stereo, Speakers, Amp and MTX Subwoofer HID Lightforce Suspension stuff flexy 2" Report
May 13, 201214 yr Author comment_1862 But didn't like the fridge slide so that got scrapped and stuck to the basics And added a bed, its big enough to fit our double self inflating mattress on with room. Its strong enough to hold the woman and me (not that we are big). The top folds in the middle with a piano hinge and just sits on top of the draws when not in use. Report
May 13, 201214 yr Author comment_1863 Started on my second glove box, still got a bit to do. I can't work out a nice looking way of putting a latch on or some way of holding the door closed. I put a glovebox light in because Mr Nissan doesn't think of the small things. __________________ Report
May 13, 201214 yr Author comment_1864 Then added the following - Volt, Boost & Pyro gauges - Dawes and Needle valves - Optima Aux and Century Starting batteries - ARB Compressor mounted under the passenger seat - ProComp alloys - DIY Sliders - DIY Rear bar - CAT Mudflaps - Tigerz11 12,000lb winch with rope with the control box mounted behind the grill but in front of the radiator support panel. Looks stealth! - HiLift Jack - Telescopic rear work light - Full length drawer and storage system, made heavy duty as the old stuff didn't last. Made of 20mmx20mm box with 15mm ply and 227kg runners. Much stronger, will be semi-impossible to break it now! - Carling (ARB style) switches for rear work light, compressor and manual override of the battery isolator. - Mounted a fire extinguisher in the rear - Fishing rod holder - Also added a Snorkel while I was at it - And replaced a heap of worn parts! Here are some pics! The drawers are not finished, still have to line the whole thing with carpet to get rid of the thudding sound that come with having wood instead of seats and carpet. The lid folds up so i can put the fridge in the drawer, the missus is a short ass and can't reach it on top and we sleep in the back so that is why I have done it this way. The only problem is now i have to put the fridge on the front seat while we are sleeping, which isn't a real biggy, still quicker and easier than setting up and pulling down a tent. There is now plenty of storage space! Report
May 13, 201214 yr Author comment_1866 And this is how it is now (for now) Procomp 16"x8" alloy wheels 285/75R16 BFGoodrich KM2 mud tyres 3" Suspension lift, with flexy coils, Bilstein Shocks, Superior Drop Boxes, Superior tie rod, HD drag link, extended sway bar links Front Air Locker with compressor Marks Adapters 43% Transfer Reduction Gears AVM HD manual hubs Dual Batteries with Red Arc solenoid, one century battery & one optima deep cycle Steel dual wheel carrier steel rear bar (only has one carrier), comes with & holds highlift jack, shovel, rear work light, axe. (Will do a DIY thread for this) Steel rock sliders/sill protectors Dawes Valve DPChip performance chip 3" exhaust with hi-flow cat & muffler Full length storage system, enough to fit queen matress on, fridge fits in drawer, massive storage space. ARB Aluminium roof rack Thumpa Inc LED lightbar with combo spot and spread lenses. 3 Lightforce XGTs, 2 converted to 55W HID HID headlights LED front indicators/parker lights Uniden UHF with scanner & GME 80 channel with GME antenna Boost, Exhaust Gas Temperature & Volt guages Cross Country Intercooler with draw through fan Steel Bullbar with Warn 9,000lb winch with Dyneema Rope & solenoid box securely mounted under bonnet. Fiberglass AM/FM radio antenna Cruise Control Second Glove box Waeco CF50DZ fridge and freezer Pioneer DVD/iPod/MP3/CD radio with Pioneer speakers, sub & amp Report
May 13, 201214 yr comment_1896 Tough rig, big fan of that colour too. Looks like you have the best of both worlds (capable off road rig and tourer). Report
May 13, 201214 yr comment_1902 Sweet setup heyhey. Do like your storge area. Looks well built. Report
May 13, 201214 yr comment_1903 very nice looking mate, well done. Top effort on the the draw setup. Report
May 13, 201214 yr comment_1945 I spy a ktm and a bundy can! Love your work! Oh an the cars not bad either Report
May 14, 201214 yr comment_2192 Nice truck mate done very well. Do you have any idea how heavy your rear bar ended up? I'd love to give one a go myself but concerned ill make it to heavy Shane Report
May 14, 201214 yr Author comment_2193 Without the carriers on I can lift it by myself alright, probably about 50kg maybe a little more bare. Report
May 14, 201214 yr Author comment_2200 Shane, I started a thread with pictures of the build. Not sure if you saw it or not? Report
May 14, 201214 yr comment_2207 Yeh I did have a look there thanks. Was just unsure of the weight. Shane Report
May 15, 201214 yr comment_2281 Nice looking ride seems to have all the fruit too any other plans for it now or is this completed stage ? Report
May 15, 201214 yr Author comment_2347 At this stage, she is beyond complete, being dismantled and reassembled to close to standard plus some extras. I have a GU Ute so transfering most things across. I'll be starting a thread on that build shortly. Report
May 15, 201214 yr comment_2358 Ah ok then saw you were looking at brake upgrades too on the other place Report
May 15, 201214 yr comment_2371 lookin' good , now strip! usually the way it goes. . . . you putting your wheels across? i'd be interested in em if you sell. Report
May 15, 201214 yr Author comment_2378 Wheels can come off, I won't be using them as I'm looking for GUIV or later alloys (maybe or alloy beadlocks??(money(i'm just not sure(damn)))), but currently only have 4 as when I had one break off (yes don't ask, my bad) it was damaged pretty bad. Report
May 15, 201214 yr Author comment_2379 Ah ok then saw you were looking at brake upgrades too on the other place Yeah, looking for the ute. I hate Patrol brakes Report
May 15, 201214 yr comment_2391 That kit is not a perfect fit for gu patrols the first kit and prototype is on my old mans car te top of the caliper needs to come in on the drivers side I can give you all the parts numbers so you can source the parts locally if you wanted to Report
May 15, 201214 yr Author comment_2398 Yeah that would be great. So, why does the caliper need to move on the drivers side? I don't quite understand what the problem is. Report
