June 10, 201313 yr comment_7350 Hi guys, So my 01 gu has been having some problems from time to time, and not sure really what it is.. Scenario is. Low range, first gear, steep decent. So I am off the brakes letting motor and gearbox do its job. Then all of a sudden I hear a cluck/knock, car lurches forward for a sec, then goes back to holding its own wait. I am not sure if it is me or not but it feels like steering gets a bit tighter right before the knock. It only happens in this scenario. Low range, under acceleration is fine, it just when the wait of the car is on it. Any ideas, happy to hear them all? Cheers Olly Report
June 20, 201313 yr comment_7377 Almost feel like saying, are the tyres loosing grip? Or is it one of the suspension components moving/worn?Cheers Edited June 20, 201313 yr by Rumcajs Report
June 20, 201313 yr comment_7378 Could be the front or rear diff missing a few teethSent from my Nexus 4 using Tapatalk 4 Beta Report
July 30, 201313 yr Author comment_7420 Well I am taking a punt and getting rid of the auto hubs. New manual ones going on this weekend. Then see if that helps this. Will report back once tested. Report
July 31, 201313 yr comment_7422 How are your tyre diameters?Even though you have all the same size, the actual rolling diameter differs brand to brand.So yes, you auto hubs could be disengaging, but this would easily be fixed by changing the auto hub to the locked position..Sent from my C6603 using Tapatalk 2 Edited July 31, 201313 yr by BigGQWesty Report
July 31, 201313 yr comment_7424 Aaand, converting the auto hubs to manual only is a 15 mins job and is reversible. Cheers Edited August 2, 201313 yr by Rumcajs Report
August 2, 201313 yr Author comment_7426 Tyre dia should all be the same. Tyres are all the same replaced at the same time. Report
August 19, 201313 yr comment_7447 How did the New hubs go? Kallen WestbrookOwner ofWesty's Accessories Report
September 5, 201313 yr Author comment_7482 Hi mate. I have swapped them for manual hubs, but haven't had a chance to lock it in 4x4 since, so not sure yet if I have fixed the issue. I will update here when I know. Report
