May 9, 201214 yr comment_1079 Just a quick guide on how i replaced the indicator assemblies in my factory Nissan Winch Bar. I bought the replacement units from OzLED. You can get cheaper versions direct from China, but OzLED supplies to the emergency services here in Australia and the lights are ADR Approved so you wont have any problems with insurance or the Fuzz. The set i bought fit exactly into my bull bar, the only thing i had to do was the wiring. Being that i prefer to solder and heat shrink everything (i hate those dodgey crimp things!!) the job took a little bit longer. The lights come in a pack of 2, are fully sealed and have this chrome bezel to finish it off. A picture tells a thousand words so its perfect to show how the wiring gets done. Drivers side Passengers side Old New Parkers old and new Indicators old and new Quite an easy mod, stops the dreded "my indicators are full of mud and water" issues and i think looks pretty good. Report
May 9, 201214 yr comment_1093 The boys @ Ozled also do the 175bar which will screw into the light bracket/holder that is in ARB bullbars as well nice and easy cheap mod to do. Report
May 10, 201214 yr Author comment_1197 Looks great Have you got a part number for them G'day Russ, Sorry i dont have it anymore.. If you give the guy at OzLED a call and tell him what model car you have he will be able to tell you. Perhaps post it back here for us all to see? Report
June 3, 201214 yr comment_4365 Geez, I'm after exactly the same thing that part # would make the life easier..... Cheers Edit: I had a look at their entire catalog and as far as I can tell from it, those lights have part # 175AW. Dronus are you sure the mounting holes spacing is exactly the same? Edited June 3, 201214 yr by Rumcajs Report
June 5, 201214 yr comment_4434 That's the number I went hunting and found this is what is supplied from tweaked offroad Report
June 5, 201214 yr comment_4468 I got them this morning from OzLED in Melbourne, they don't look exactly the same as the ones on Dronus's rig exactly (no chrome bezel ) . They do stand apart and work the treat. I couldn't however bring myself to solder the wires so proper weatherproof connectors were in the order. Anyone wants/need spare second hand OEM indicator/clearence lights covers? Cheers Edit: for those who have fitted these ligths and find the main headligths parkers too yellow you can get replacement LED T10 wedge type from Jaycar part # ZD-0394 cheaper than from fleabay or else. Edited June 12, 201214 yr by Rumcajs Report
