June 11, 201213 yr comment_4686 Ok.. Been bugging me for a bit.. I got every other light on the bus (finally) working but this one.. I started by pulling the light out and checked the globe.. All good. Plug is good on low but nothing on hi. I've pulled the steering column apart to check the switches. All is good there but I did notice that the driving lights have been wired into this wire also to the solenoid so I'm not sure if this could be my issue.. So what am I missing?? Report
June 11, 201213 yr comment_4700 Individual fuses? Corroded terminals?Bad earth?Is the globe actually alright?! Cheers Report
June 11, 201213 yr comment_4702 Sounds like someone might have used one of those dodgey crimp connectors to get a hi beam signal for spot lights... Sent from my Galaxy Nexus using Tapatalk 2 Report
June 11, 201213 yr Author comment_4703 Have checked fuses. Both are fine. Might pull the box out and check behind it.. All connections look clean and no dodgy crimps. All soldered apart from the solenoid. I pulled the feed wire off it still no good. Globe is fine, but as I mentioned I have no power at the plug.. It's looking more like a broken wire.. But I'm not pulling the loom apart to find it.. Lol Report
June 11, 201213 yr comment_4707 Does the high beam warning light in the dash still light up when on high beam? If it does your problem has to be either a faulty bulb or a bad connection in the headlight plug or possible a break in the wiring running from the headlight into the switch. If your high beam light doesn't work (assuming the high beam warning light bulb is not blown) then the problem is more then likely dirty contacts in the switch. The Red with a Green trace wire at the headlight switch should have power in it when on high beam, if it doesn't, the problem it with the switch contacts. You can try bridging power from the Red with a White trace wire (in the same plug) to the Red with a Green trace wire to confirm the RHS high beam comes on. Edited June 11, 201213 yr by Yendor Report
June 11, 201213 yr Author comment_4719 Thanks Rodney, I'm not sure about the dash light.. Will investigate. As mentioned before I do have power at the hi/low switch and is switching on and off as it should. So to me that's fine.. Report
June 12, 201213 yr comment_4737 The headlight part of the combination switch has 4 separate contacts. One set for drivers side low beam, one for passengers side low beam, one for drivers side high beam and one for passenger side high beam. So when you turn high beam on you should have power in two wires coming from the switch (Red with a Green trace wire and Red with a Black trace wire). The high beam warning light in the dash also gets it power from the same switch contacts as the drivers side headlight (Red with a Green trace wire). Because your high beam warning light also doesn't work I believe it's this one set of contacts that are dirty/faulty in your switch. Edited June 12, 201213 yr by Yendor Report
June 12, 201213 yr Author comment_4740 Ok. Are you guys taking about GQ's or GU's.. Mine has 3 contacts. And each set is in pairs. One for side lights, one low and one high.. Report
June 16, 201213 yr Author comment_4900 You were close Yender.. After pulling apart the whole dash to discover the Hi beam light is fine (switch indicator and hb bulbs) I worked back to the switch.. I don't know what I was thinking but the was no power at the crimps. So I've popped the back of the contacts part of the unit to find no power at all to the contact do the RHS.. Now these are a moulded box so the lid is as far as you can dig so what I have done is jumped power from the LHS one.. Hope this works... Report
June 16, 201213 yr Author comment_4909 And I have lights... Yay.. I recon this is the first time in a decade that all the lights have worked at the same time... Thanks for the help guys.. Report
June 16, 201213 yr comment_4921 That's a strange one, normally it's just dirty contacts. You repair is not ideal, you now have both the LHS and RHS high beam running through the same fuse. Normally this is not a problem but the GQs have a problem with melting the headlight fuse holder when only one bulb is running through it. You would be better off using a relay. Edited June 16, 201213 yr by Yendor Report
June 16, 201213 yr Author comment_4923 Would it though?? If the fuse is after the switch then it should be fine.. I might check that tomorrow. Report
June 22, 201213 yr Author comment_5071 Well it's been a week and it's still going strong... Highway driving every morning and the whole lot looks like its going well.. Fuses are good, points are good.. Report
June 23, 201213 yr comment_5103 I'd fix that properly if I where you. One of my mates did a dodgy repair job like that and it lasted a couple of months before it melted everything in the switch and had damaged a few other wires in the loom and lost his lights in the middle of no where. I kept telling him to fix it but he new better. lol It ended up costing him nearly $1000 to replace half the loom instead of $100 for a new combination switch. Don't cut corners with wiring especially something as important and lights. They will fail when you least want them too it's Murphies Law. Cheers Mick. Report
June 23, 201213 yr Author comment_5105 Was he running ridiculously over sized globes though? I'm only running the 55/110's and the size of the contacts IMHO and a good electrician mates HO recon there fine for the wattsI'm running threw it. I'm still only running a 15A fuse to. But if I do go a bigger globe I'll change out the unit. Just to be sure. Edited June 23, 201213 yr by BigGQWesty Report
