June 16, 201214 yr comment_4910 Hi all, does anyone have a thought to what might cause a low idle rpm, its a 03 zd30 auto and it idles at only 400 rpm , also when you select a gear on flat ground it won't idle forward or back , drives well no other issues, could this be related to timing? Any thoughts? Cheers. Report
June 16, 201214 yr comment_4914 That shouldn't be related to timing. What happens when you use high/warm up idle switch? Do the engine revs increase or not? Cheers Report
June 19, 201214 yr comment_4987 I would be getting injector pump checked out. I have a similar issue were it will idle low for a second before correcting itself or a quick stab of throttle on the odd occasion Report
