GQ Extra cab
Its been 2 weeks in the making and iv finally got it all together and now just need to raise my shock mounts on the rear to accomadate the new rancho's i got.
  • Replies 79
  • Views 48.9k
  • Got some rancho rs9000 adjustable shocks showing up maybe this weekend, they measure 930mm open and 545mm closed that hell beats my tuff dogs at 500mm closed and 760mm open. When i weld in my new dro
  • bit of tray work, diff brace, flares on rear, front bar
  • how it sits atm with 8" of total lift on 35's painted my snorkle black and new brake lines for the big lift broke my shock mount off my diff on weekend play mish
alot of bolt in stuff is easy providing you can show nice strong clean welds good high tensile bolts ect and looks the part no dodgy looking, suspension brakes and steering mods are the hardest to mod plaate as thats 100percent safety right there.
  • 5 weeks later...
Well its been awhile, my rig been sitting with a dead alt and a flat tyre so i started ripping the alt out replaced the coil, points, give it an extended rotor button and new cap.
Also decided to flush the old coolent out and give the power steering a service and new oil, while i am waiting for the new alt i decided to put it in the shed and started ripping the radius arms out to fit a wizard 5link into the front.
Got started on this today at 1pm and geez not overly impressed with the setup so far, the drop boxes for the lower arm needed some major grinding to get it to sit right and to get the cross member bolt holes to line up then the bracket on the chassis for the upper arm is all wrong it should have been made so the chassis mount for the upper arm was higher and more forward then the lower and it flex's really bad off the chassis so im going to have to add a few extra bolts and later on ill make a new bracket for the uppers to relocate them properly.
So basically 6 hours later i had one side mounted up now tomorrow i just need to go get some new bolts and get stuck into the drivers side and it will be all bolted up and finished by wednesday arvo ready and waiting for my alt to arrive so i can go give it a test. :)
this picture shows where i need to add bolts now to stop it flexing and where i want to move that mount later in the year.
your a talented man Evil. what's your day job?
Just a delivery driver (courier) atm lol Should of stayed in school wanted to be a Mechanical Engineer but iv dabeled a bit in a few fields, Truck Diesel mechanic/fitter, motor mechaic, boilermaker, Automotoive spray painting, Im good at everything but an expert at nothing lol
Yeah all in now just need to fab one more coil retainer for the front and should be ready for testing when the new 100amp Alt is on
there nothing flash mate just a piece of 6mm thick plate that a folded one end over to pull the coil against the seat to stop it floating around seems to be working in the shed have to wait till road test and see if they hold up :) ill put a picture up tomorrow.
Simple as... Top and bottom on yours?
Nah just bottom mate, need to extended bumpstops on front by 80mm so i think the 80series style will work just fine so ill change to them and then use the fronts in my rear.
The ides for how i made it was just to pull the coil back against the seat to stop it wanting to spin while flexed so it lines up with the upper coil seat.
  • 4 weeks later...
Here is the long awaited flex shots with the 5 link in the front, thast only 6" shocks so im ordering new flexi coils and new longer shocks soon as i get other things on the list that are much needed done.
