May 11, 201214 yr comment_1633 My TD42T It was stock when i bought it 3 months ago. I bought it due to the old Grandpa that owned it, its only done 140,000klms So far I've added: 33" muddies Tradies roof cage High lift jack and shovel 3" exhaust no mufflers 15psi Maxed out stock injector pump UHF Autometer boost and pyro gauges Alarm system and central locking tigerz11 winch Narva 225's with HID conversion Edited July 19, 201214 yr by Dye-04 Report
June 11, 201214 yr Author comment_4671 Bit of an update, I fitted a tradies roof rack setup with awning, high lift jack and shovel New shoes. 15 x 10 -44 Allied thunders 35" BFG Muddies. Ordered a 3" flexi lift kit from Suspension Stuff Report
July 19, 201214 yr Author comment_5902 Time to extract some more power out of the TD42T Garrett GTX2863 turbo Frozen boost water/air cooler Cooling mist Water/methanol injection I'm currently making myself a new inlet manifold. pics will come once its finished. I'm also tigging up a 15L water/meth tank in the engine bay. Report
July 22, 201214 yr comment_5975 Your is a dream purchase, nothing I'd like more than to come across a vehicle like that. I see you've also added sliders/steps as well. Have you still got a stock exhaust on that thing? Cheers Report
July 22, 201214 yr Author comment_5978 Your is a dream purchase, nothing I'd like more than to come across a vehicle like that. I see you've also added sliders/steps as well. Have you still got a stock exhaust on that thing? Cheers No mate, its 3" with no mufflers Report
July 22, 201214 yr Author comment_5988 Quick picture after I fitted my 3" Suspension stuff lift. I also fitted rubber flares, that i hate! But, im trying to keep it semi Legal. haha Total pain in the arse trying to fit the caster correction bushes without a press at home! Edited July 22, 201214 yr by Dye-04 Report
July 23, 201214 yr comment_6011 I'd vent that meth tank clear of the vehicle as possible. Meth will boil out at 65 and on a nice hot day sitting next to the exhaust, I think it would get there pretty easy especially after a nice long heat soak. Even at 50 it will give off plenty of fumes and you sure as hell don't want them coming back in the cab or anywhere in the engine bay they could ignite. Beautiful fabrication on the tank and manifold. Wish I had those sort of skills and ability. Report
July 23, 201214 yr Author comment_6013 Thanks for the tip Glort, once the new turbo is installed, i might have to chop a bit off the tank. I will be sure to vent the tank somewhere safe. As for the fab skills, I'm really only a beginer, I bought myself a Tig, watched some videos on you tube and taught myself. Report
August 10, 201214 yr Author comment_6264 Twin 10" Thermo's installed, Hopefully it will keep cooler temps low and help out the A/C Condenser now its completely blocked by the cooler. 15mm Thick high density foam to direct the air straight from the Thermo fans onto the A/C condenser Trial fittment whilst i start to fab up some brackets to hold it in place. Report
August 11, 201214 yr comment_6271 So your still running the belt driven fan and 2 10" thermo fans?? Why not disconnect the belt driven one and put the 2 10 in the rear? But I like the snorkle. Is that 3 or 4" Edited August 11, 201214 yr by BigGQWesty Report
August 11, 201214 yr Author comment_6272 There is a large gap between the A/C condenser and the radiator. If i put the 10" thermos on the radiator it wouldnt really draw the air through the cooler condenser and radiator all at once. My background is turbo petrol engines, from my experience with them, nothing beats the factory engine fan. I had to put 3 x 10" electric fans on my last car just to take the place of one engine fan. So I'm going to leave the standard fan there for now and see what happens The snorkel is 4" from Millweld. Its great! It took me about 30mins to fit it. Report
August 11, 201214 yr comment_6275 Fair call. Factory fans move some air... And nice job on the snorkle Report
February 17, 201511 yr comment_8249 your patrol looks great, like what you have done so far, Its amazing how passionate you can get with modifying your forby. every time I do something new I think that will be it, then along comes a new idea.. great photos Report
May 26, 201511 yr comment_8358 I like the inlet manifold !! I see this thread has lost some momentum.... Hopefully Dye-04 sees this and adds some new pics of the finished manifold and water/meth tank !! Report
