In car USB charging DIY
OK, So im sick of having cigerette plug double adapters, cables going everywhere, phones falling out of the overhead thing and - not being able to charge my Samsung tablet while its running unless its plugged into a 240 inverter socket.
The problem comes from the fact that a normal USB socket can only supply 500ma. if you are lucky and can join 2 together (or have a high power USB port) you can get 1A. Tablets need around 2 A to charge and run at the same time.
I had a 1A usb plug which was fine for my phone, but not the tablet.. Increasing the charge supply might also speed up the charge time for phones, cameras etc.
These just arrived on my desk from the states, my plan is to remove them from their cases and mount them in small jaycar boxes, and then around the car, just running 12V to each.
They have 2 ports - one is 1A the other is 2.1A
More pics to follow as i install them into the car.
Nice little project Dronus. Looking forward to it. You can buy car USB ports from baintech, too, although I don't know what Amps they were.
Sent from my iPhone using Tapatalk
Found some little boxes in jaycar.. Was the smallest i could find so ill have to use them.. Prob good to keep some air around the circuit board anyway..
Some will be hard wired with USB cables, but at least one will be under my EGT gauge covering a hole i butchered..
Stay tuned :)
If that's what you're considering, why not consider what I did to make an extension point for my USB GPS antenna (it's a switch blank on the side of the console):
It allows me to connect to my tablet, without having cables strung all over the car. You can easily fit two USB ports to each switch blank.
Ray
Edited by Ray!
The best place is the wreckers. Nissan sell them but want the usual arm and leg for small, not oft, requested parts. Normal switch blanks may also fit, as the factory ones are pushed in from underneath, but I have switches that click in from the top.
Ray
In my GQ I filled several switch holes with switches I pulled from a commodore.
Exact same size.
I don't remember any blanks on the one I had, it was a more upmarket version with a lot of extras but maybe the poverty packs have some blanks in theri dashes?
Geeyoutoo had a USB port on his dash somewhere too.. my stereo surround fascia is getting pretty butchered so I'll chuck one there, one up in my overhead console and I'm thinking about putting one in each rear door for the kids..
I'll give it a crack on the weekend.
Hi all,
ive converted my airbag dummy cover to a second glove box and run 4 cig plugs
these are powerd 24/7 from aux battery and i run gps, i pod ,i pod transmitter & laptop charger
all behind the hinged lid neat and tidy
Alan
Hi all,
Alan
Post up some pics of your setup if you have them, it sounds pretty cool.
Maybe start up a new topic to keep that mod separate to this one?
Picking up a dremel and new hot glue gun tomorrow, should have some pics of this mod up this weekend.
Yeah im a bit peeved that my sony xplod cable wont charge my ipad, i was hoping to use it to charge AND play music from my 64gb ipad 1
I made sure the stereo I bought would charge and play. I couldn't believe it when I heard that some wouldn't. Kinda stupid really.
